new guy with scrambler ???s
Old Mar 16, 2009 | 04:14 PM
lsmonte350's Avatar
Default new guy with scrambler ???s
I just bought a two stroke scrambler. the guy said its a 96 but the heads have 350 on them. i dont know much about atvs but did they make a 350 scrambler? or are the heads the same ? any help will be appreciated.
Old Mar 16, 2009 | 04:21 PM
BlackRaptor's Avatar
I don't think they made a 350? one quick question would be the word *heads* should only be one head on a single cylinder engine. Scramble 400 was a single 400 my Xplorer has the same engine in it and it says 400 right on the top of the head.
Old Mar 16, 2009 | 04:23 PM
ftwflh's Avatar
Some where along the line a 350 could have been swap into it.The 350 and 400 are basically the same.But a 400 has more power
Old Mar 16, 2009 | 04:27 PM
lsmonte350's Avatar
sorry i did mean single head. the spark plug threads are messed up so i need a helicoil. which gaskets do i try to buy? the head does say 350 on it. i was wondering if someone swapped just the head if they interchange.
Old Mar 16, 2009 | 04:41 PM
ftwflh's Avatar
91-early 94 were 350Ls 94-up were 400s and they are a easy swap.I would bet yours was swaped out at on time.
Old Mar 16, 2009 | 04:54 PM
lsmonte350's Avatar
ok so i am most likely gonna buy parts for a 350L. I was thinking maybe he swapped out the head if they were the same. also is this a solid motor?
Old Mar 16, 2009 | 05:01 PM
ftwflh's Avatar
Just as good as a 400 but a little less power.I dont think the heads will interchange
Old Mar 16, 2009 | 05:16 PM
lsmonte350's Avatar
ok.i am still a little confused. but i think its probably a 350L. the transmission and everything else will mount to this motor with no problem? Thank you already for th quick responses.
Old Mar 16, 2009 | 05:35 PM
lsmonte350's Avatar
sorry to be a pain but my new question is if anybody knows for sure if these heads are the same.thanks again
Old Mar 16, 2009 | 08:26 PM
ftwflh's Avatar
From the parts break down the heads are dif.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
