Honda trx420 lift kit
I want to install a 2" lift on my 420 but I can't get a straight answer on if I need front wheel spacers on it. One dealer says yes, another said no, the lift kit box said yes. I will be adding 25" mud lite tires when I am done.
Has anybody used a lift kit and did you need front wheel spacers?
Any and all comments are apreciated...
Thanks in advance...
Sorry after rereading my original message i realized how unclear I was. I use my quad alot on very rocky surfaces and need the clearance so I don't get high centered.
I will be adding the lift kit what I need to know is do I have to spend the $100 on the spacer kit to bring the front wheels out? Or will they hit or rub somewere?
Thanks in advance.
Thanks in advance.
i had 28x10.5x12 outlaws on mine and they would only rub on my winch when i turned sharp to the right, thats because thats the side that the winch motor stuck out of the fram on. i have pics if you want to see my rancher with those tires on it
I would like to see the pics, would you like to e-mail them to me or post the here?
Also did you have a lift kit on it?
You said you run 28" tires on yours, do you run a honda 420?
Did you notice alot of power loss going from 24" to 28"? Alot/alittle?
I was only going to go to 25" but I may think differently...
Thanks...
Thanks...
