Anyone having starter problems with raptor?
My starter is acting up not sure if it may have water in it and got frozen which I doubt but it is making all kind of noise and wont engauge all the time this just started yesterday and it also sounds like it stays engaged once started for a little while it has done this from new. Just wondering if anyone else has had any problems.
xtreme165,
I have the same problem with my machine. It makes noice for about a minute or so upon cold startup and then goes away. I have about 20 hours on my machine. Let me know what you find.
Thanks,
IronBear
Thanks,
IronBear
My starter was doing the same. it would some times do ok and other times it sounded terible. but i took it back to the dealer and they replaced the gears. they said it had some missing teeth or something to that nature.
Mine starts fine, always has, no battery or starter problems... Just had to throw that in to break up the line of people all having the problem. Dont want anyone to think every Raptor has issues.
My Raptor and also my friend's both make a buzzing noise coming from the starter area when started cold. It sounds like gear teeth slightly touching each other and making a buzzing sound. It goes away when warm. I took it the the dealer and the mech said it was because of the dry sump design not supplying oil right away to that section of the engine.
P.s. I also had a 1985 Honda XR350 (kick start only)that did the same thing.
