Scrambler clutch. HPQ?
Old Mar 17, 2009 | 10:45 AM
Scrambler00's Avatar
Default Scrambler clutch. HPQ?
ok ive made this thread before and got some good advice. Well in the past my primary lost a chunk off the top of the inner sheave. I replaced a remanufactured one to replace it and the spot where my new clutch was welded has cracked again the company will not take it back [img]i/expressions/face-icon-small-sad.gif[/img] . So im thinking out the HPQ, its cheaper than a factory one, i know they are hard to tune.
but would a performance/ polaris pro be able to tune it in for what i want, i have the AAEN top end pipe and clutch kit already.
So would i use the same AAEN springs i have and all that?
Is a different belt needed?
also royal distributing offers it pre calibrated for the atv? yay or nah?
thanks in advanced sorry to be a pain again, also anyone with a personal experience with it please help
Old Mar 17, 2009 | 04:53 PM
ftwflh's Avatar
Get you a used primary clutch off Ebay and use the sring and weights out of the old one.New primary clutches are too expensive.
Just ask the seller how much play is in the buttons and if the slide towers have much if any wear.
Old Mar 17, 2009 | 04:57 PM
I've never used Ebay lol, im currently trying local cycle salvages but they are apparently rare. So your still saying no dice on the HPQ, what would happen if i got it and stuck all the weights and springs from my current clutch on it? wouldnt work the same or is it just that different?
Old Mar 17, 2009 | 05:01 PM
ftwflh's Avatar
I have never messed with an aftermarket clutch.THe Polaris clutch is abut as good as it gets when set up properly.
Check out Ebay do a search for Polaris atv clutch and any non EBS clutch will work.should be able to get a good one for less than $100
Old Mar 17, 2009 | 05:03 PM
I will giver a go. I asked a local polaris mechanic who knows his stuff, he said he'd probably be able to tune it in though
Old Mar 17, 2009 | 05:15 PM
ok so on ebay i found some, are u sure all no EBS clutchs are the same? like even new ones
Old Mar 17, 2009 | 09:14 PM
ftwflh's Avatar
EBS wont work unless you have both clutches and a EBS belt.I will take a look on ebay and see what I can find that will work. then post you a link.Send me a pm with your email address I found a bunch that will fit yours.
Old Mar 17, 2009 | 10:18 PM
http://cgi.ebay.com/ebaymotors...ADME:X:RTQ:MOTORS:1123
its from a 400 sportsman.
http://cgi.ebay.com/ebaymotors...rksid=p4506.m20.l1116
this next one is the cheapest http://cgi.ebay.com/ebaymotors...trksid=p4506.m20.l1116
Old Mar 18, 2009 | 05:57 AM
ftwflh's Avatar
First one is way tooo $$$$$
second is decent
third fair
here are some more links
http://cgi.ebay.com/ebaymotors...:IT&item=250388600769
http://cgi.ebay.com/ebaymotors...:IT&item=390037239116
http://cgi.ebay.com/ebaymotors...:IT&item=290302938739
http://cgi.ebay.com/ebaymotors...:IT&item=310128488394
http://cgi.ebay.com/ebaymotors...:IT&item=220379195881
On ones with make offer dont offer more that $100 US
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
