EPI Clutch springs
Old Mar 17, 2009 | 11:01 AM
dustin8201's Avatar
Default EPI Clutch springs
Hey everyone. I have a 2006 Sportsman 500 EFI H.O. I have stock 26" tires on it and we do mostly trail riding with the occasional mud pit. Nothing super gummy, just typical mud. My question is should I by just the springs and if so what color/s or should I just break down and buy the Sport Utility kit? I am not wanting to spend the $200 for the kit, but don't know much about the springs to justify which one I would need for the primary and secondary of the secondary is needed. Any help on this subject would be great. Thanks,
Old Mar 17, 2009 | 04:49 PM
ftwflh's Avatar
Try an EPI pink primary spring and a 500 Scrambler secondary spring if cash is tight.
Old Mar 18, 2009 | 09:22 AM
dustin8201's Avatar
Does changing the helix make that much of a difference on a pretty much stock bike? Is there different colors of the secondary spring for the scramblers?
Old Mar 18, 2009 | 07:29 PM
ftwflh's Avatar
try a primary spring first.Then try a stiffer secondary
Old Mar 18, 2009 | 10:56 PM
plumbob's Avatar
The secondary spring from a scrambler will not work because the Sportsman 500 EFI has a roller secondary and the scrambler does not.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
