06' Sportsman 800 wont start
Old Mar 17, 2009 | 01:34 PM
sportsman800mn's Avatar
Default 06' Sportsman 800 wont start
I was riding my wheeler the other day and shut it off and went to start it up and nothing........Full battery charge, lights turn on but when i turn the key to start it nothing happens, doesn't click or make any noise. HELP!
Old Mar 17, 2009 | 01:53 PM
Anyone?
I do not know much about fixing but a little guidence whether is a starter or cylonoid would help. Thanks.
Old Mar 17, 2009 | 05:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you ned to start right back at the battery and go up from there checking for power and checking the connections including grounds. make sure there isnt any corrsion issues as well. you may have a breaker issue so check for that as well. check all the fuses for any blown ones as well.
Old Mar 20, 2009 | 09:22 AM
rustyCJ's Avatar
I had the same thing happen on my 05 700, turned out to be the starter solenoid. Its under the rear drivers side fender mounted to the frame. You can jump the two terminals with a screwdriver, if it turns over when you do this the solenoid is most likely bad.
Old Mar 20, 2009 | 09:43 AM
Took a voltage meter to it and found it was just a loose cylonoid connection. Thanks for the help.
Old Mar 20, 2009 | 09:46 AM
rustyCJ's Avatar
Glad you got it fixed, its always nice when it is something simple.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
1000gade
May 27, 2015 12:37 PM
