need solid spark plug terminal... help!
Old Mar 17, 2009 | 03:43 PM
Hawkman300's Avatar
Default need solid spark plug terminal... help!
i bought an ngk iridium spark plug for my 06 polaris hawkeye 300 AWD. it has the screw on type tip instead of the snap on tip like the stock ones. how should i connect it?
Old Mar 17, 2009 | 03:57 PM
colt2245p's Avatar
if it needed an ngk iridium plug it would have came one from the factory..........save your money and the headache and put the correct plug back in it...
scootergptx's Avatar
Supersock
Hired Gun!
Can you just unscrew the tip off the old plug?
Old Mar 17, 2009 | 07:24 PM
Hawkman300's Avatar
an iridium plug is and upgrade from the factory plug, 100% designed replacement upgrade. and no, it wont twist off from the factory, i tried and it cracked the white part on the plug, it was an old plug anyways tho. and yes, the iridium plugs do improve performance. i put one in my rancher and it sounded better and ran smoother and revved quicker. i just need the little tip that goes ontop of the threads to make it snapon for the polaris. the hondas fit the threaded tips.
Old Mar 17, 2009 | 07:47 PM
TennesseeTider's Avatar
I had the exact same problem when I put the iridium in mine. I just went to oreillys auto parts and they found a cap for me for free.
By the way the bike will run better with the iridium. mine did, I don't care what anyone else says about it, whether it should or should not work, but it does.
Old Mar 17, 2009 | 07:54 PM
trickie79's Avatar
it will unscrew hold the plug were you would put the wrench.then vise grips on the end you need unscrew wala done thay all unscrew.
Old Mar 17, 2009 | 07:57 PM
trickie79's Avatar
does any one out there ever talk to a new guy that knows alot about 4 2 wheels
Old Mar 17, 2009 | 08:45 PM
Sisco1957's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Hawkman300
You are right, not all plugs have the screw-on tip. Might check the part stores or a repair shop. All tips may be the same.( cars,lawn mowers ect.)
Old Mar 17, 2009 | 09:40 PM
Hawkman300's Avatar
ya, ill just go to some autoparts stores and see what the have...
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
