850 xp bolt pattern
Old Mar 18, 2009 | 09:39 AM
BPM's Avatar
BPM
Default 850 xp bolt pattern
I'm in the market for some new wheels.
Before i order i wanted to make sure i get the bolt pattern right.
They are 4/156 right?
I've herd i'll need differnt lug nuts also any help there would be great.
Also has any body had issues with ITP SS212 off sets. Front 4+2 Rear 5+3.
I know the machine will be wider but i'm ok with that.
Thanks
Old Mar 18, 2009 | 11:19 AM
HIGHOCTANE's Avatar
Yes it is 4/156. You will need metric lug nuts 10mm with a 14mm..the lug nuts are recessed on the ITPs and you can't use the stock lug nuts because you won't be able get a socket on the stock 17mm hex lug nuts.
Old Mar 18, 2009 | 12:07 PM
BPM's Avatar
BPM
Thanks H.O. I knew you guys have been through this berfore.
Old Mar 19, 2009 | 09:05 PM
03fatboy's Avatar
Just to let you know the lug pattern is the same but the offset is a lot different and also center hole is a lot smaller than the old style Sportsman. So if you use wheels that are not made for the XP they are going to stick way out. I just went through this getting XP wheels to fit on my 09 Sportsman 800. I had to space them out 1.5 inches. and now they sit in the stock location. I think polaris is the only co. making any wheels that fit the new XP.
Old Mar 20, 2009 | 02:26 PM
Hotdogmb's Avatar
So, will the rims and tires off my 2002 500HO fit on my 09 850??
Old Mar 20, 2009 | 02:33 PM
BPM's Avatar
BPM
No. not unless there 14" rims.
Joe454
Nov 20, 2020 01:19 PM
blueandy88
Sep 7, 2020 03:11 PM
EIF
Apr 20, 2017 07:15 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
blueandy88
Aug 30, 2015 08:26 PM
