polaris 500 2001 wont rev
Old Mar 18, 2009 | 08:33 PM
go fish's Avatar
Default polaris 500 2001 wont rev
starts idles fine but will not take any throttle . any ideas would be appreciated. when you try to throttle it . it pops cracks and back fires
Old Mar 18, 2009 | 08:42 PM
rockout's Avatar
anything other information? has it been sitting? anything happen? sounds like it is running lean. i could see if it has been sitting for awhile, the carb has gummed up. or if something happened like a roll over or something messing up the float. intake leak, etc.
Old Mar 18, 2009 | 08:45 PM
go fish's Avatar
carb has been cleaned recently . no roll overs this year so far
Old Mar 18, 2009 | 09:27 PM
rockout's Avatar
did it start acting up since the carb cleaning or before? i guess i am trying to see if it just started acting up overnight (which would tend to meen electrical) or has it started acting up over time and just got worse and worse ( which tends to meen fuel issues)?
Old Mar 18, 2009 | 09:31 PM
xplorerman's Avatar
check the camshaft see if the exaust lobe is wore down at all
Old Mar 19, 2009 | 01:41 PM
albertaATV's Avatar
I am having the same problem with mine.
I have a 99 Polaris Sportsman 500. It was a friend of mine's dads machine and he will sell it to me cheap if I can get it fixed. It ran fine up until two years ago when it just died. It only has 2700KM on it. It wouldnt start without backfiring and stalling out.
I have had it in the shop and they have done the following work:
Rebuilt the darb
Adjusted the valves
replaced the stator
checked timing
The machine will start, idle but when you give it any gas it pops and backfires and stalls out.
They think it might have something to do with the camshaft being slipping in the web.
They are telling me that to get to the camshaft they need to pull apart the engine (about 20 shop hours worth of work) ... not sure if it is worth it if this is the case.
Any thoughts?
Old Mar 19, 2009 | 04:01 PM
go fish's Avatar
will check cam thanks for your input . this thing just started doing this out of the blue . was riding it a couple of weeks ago and it lost power .time i got back to the house it wouldnt even take any throttle but it will start and idle?????
Old Mar 19, 2009 | 04:05 PM
go fish's Avatar
yea it ran fine after cleaning the carb . just lost power that one day while riding . i have cleaned the fuel pump 2 since this happened . didnt help none
Old Mar 19, 2009 | 04:07 PM
go fish's Avatar
did they check the cdi box ?
Old Mar 19, 2009 | 04:21 PM
albertaATV's Avatar
if you're asking me... yes, they checked the CDI, tried a different coil... the shop is stumped. I am at a loss as to what to do with this thing..
