2004 sportsman 500 pulls all the time
Old Mar 19, 2009 | 05:31 PM
dogspower1's Avatar
Default 2004 sportsman 500 pulls all the time
I have a 04 sportsman 500ho that when i put it in gear it starts pulling and i cant change the gears with out turning the engine off acts like the ebs is not releaseing,thanks for any help
Old Mar 19, 2009 | 09:05 PM
atv gooroo's Avatar
The clutches are out of alignment. Bad moter mounts, belt, one way clutch, cracked primary, need to shim secondary. All of these things could cause this.
Old Mar 19, 2009 | 09:11 PM
dogspower1's Avatar
so this is the clutch on the trans is this the one with the fiber washer abd bushing ,thanks
Old Mar 19, 2009 | 11:28 PM
Jocko's Avatar
Has the belt ever been changed? A worn belt will ride up on the primary sheaves and cause the secondary clutch to spin during idle. This will cause it to "creep" as you stated and will make shifting very hard.
For starters, I would take off the clutch cover and blow out really good with shop air. Do it outside, because it gets pretty dusty. Inspect for any damage as suggested above. Change the belt and if the problem persists, you probably have a clutch alignment issue. Align the clutches as per the service manual.
Has the machine been rode hard or had any bad spills lately?
Old Mar 20, 2009 | 03:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it has some good mileage on it then guessing the worn washer or bushing as stated.
Old Mar 20, 2009 | 07:46 AM
dogspower1's Avatar
it has 1251 miles and 158 hours I just bought it and the carb had missing needle jet so it would not run much at all so i put a kit in it runs good now but has this problem now,when i bought it was clean as a new one ,but who nows,thanks scott
Old Mar 20, 2009 | 05:33 PM
dogspower1's Avatar
took cover off and the back pulley on the trans is tight side to side it will move in and out a littel bit. the front if i hold it by the outside it will move side to side a littel bit not much. but the belt is tight all the time .its ride in the top of the trans and seams to be in the bottom of the drive .should the belt be tight all the time or not
Old Mar 20, 2009 | 06:03 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes it is suppose to be tight,as thats how the ebs system works. its the front pulley (primary clucth) on the engine that has the issues. the probelm is that you can not take it apart to where these parts are that were talking about w/ out special tools and a clutch puller to take it off. when you take the belt off, on the inside on the front clutch try turning the bushing in the middle between the 2 clutch sheeves and it should only turn one way and be locked up if you turn it the other way i belave. the belt should be setting high and a little above on the secondary clutch(transmission clutch) w/ the words facing so you can read them. imo
Old Mar 20, 2009 | 11:10 PM
dogspower1's Avatar
Ok i think i found the problem took the belt off to check the one way and it was free then i took and pushed the drive clutch in by hand went right in when i let off it came back out all but like 1/2" got to looking the slideing parts and a littel rust on them cleaned them and seem to work fine now thanks for all the help
Old Mar 21, 2009 | 06:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
glad it was a simple fix. most anytime you have a creeping issue its most always the primary clutch on the engine.
