choke problems
Old Mar 21, 2009 | 07:57 PM
marqu3ll's Avatar
Default choke problems
i bought an old polaris trail boss 250 i can only get it to stay running with the choke on i turn the choke off then it dies if i leave the choke on i can ride it around and it runs finei cleaned out the carb replaced the fuel line and filter removed gas cap thought it might be vapor lock any info will be helpful
Old Mar 21, 2009 | 11:15 PM
plumbob's Avatar
Double check that the pilot jet in the carb is not plugged and you can push a wire or small diameter drillbit through it.Spray carb cleaner around crank seals and engine base gasket while running to see if it revs up from an air leak.
Old Mar 22, 2009 | 06:15 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed it sounds like a lack of fuel issue, so i would make sure you didnt miss any fuel passages and jets. use some compressed air if you have any. imo.
Old Mar 24, 2009 | 09:58 PM
war1ock's Avatar
also make sure the needle clip didnt come off. My buddys 500 was doing the same thing it turned out the needle clip fell off so the needle wasnt moving
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
ghost civic
Jul 20, 2015 12:36 PM
timster911
Jul 13, 2015 01:57 PM
Shifts
14
Jul 13, 2015 08:41 AM
