04 400 front axleshaft
Old Mar 22, 2009 | 07:19 AM
musselmark's Avatar
Default 04 400 front axleshaft
I have an 041/2 400 sportsman and the front right u-joint yoke has lateral play, I assume it is a bad bearing inside the housing. I have a shop manual for an 05 400 and it shows the shaft as having CV joints at both ends but mine has a normal u-joint at the housing end and a CV joint at the wheel end. All the online parts look-ups show this as well for 04 and 05. Does anyone know what is going on here. Thanks.
Old Mar 22, 2009 | 07:32 AM
Kerbbirds's Avatar
If you bought it used , I would say someone installed the old style shaft, ii should have boots and c-v joints on both ends, this could be why you have slack. Contact the c-v man on ebay he can get you the right shaft, great quality, great prices and service.
Old Mar 22, 2009 | 02:37 PM
musselmark's Avatar
There is nothing wrong with my shafts, I was just curious as to why they were different, I bought the machine used but it only had 1000 miles on it, could they have both worn out that early? Anyway, my problem is with the play where the shaft comes out of the housing.
Old Mar 22, 2009 | 05:27 PM
musselmark's Avatar
Also my owners manual shows diagrams as to where to grease and the picture of the shaft has CV on one end and U on the other
Old Mar 22, 2009 | 06:16 PM
eggenz7's Avatar
if its the 04.5 they switched to different style shafts then. i have a new axle for a 04.5 and it has a cv joint on one end and a ujoint on the other
Old Mar 22, 2009 | 08:32 PM
musselmark's Avatar
I just noticed that both side have play, at least 1/8", does this mean the bearings are bad, there is no sign of oil leaking out, I hope this doesn't mean the housing has leaked out long ago. What else is likely bad inside? The AWD still works fine.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
