2005 SPORTSMAN 500 RUNS LIKE CRAP
Old Mar 22, 2009 | 10:33 AM
WKbeachbum's Avatar
Default 2005 SPORTSMAN 500 RUNS LIKE CRAP
Hello All , Back with another question . Does anyone know why this machine starts running like crap when I go up an incline ? On flat ground it runs fine . It just started doing this . I have had the machine on steep slopes and it has never bogged before . Changed plug and filters . Any clues ?
Old Mar 22, 2009 | 10:39 AM
cody700's Avatar
Don't know much about Polaris but it sounds like a bowl level issue in the carb?
Old Mar 22, 2009 | 02:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it could be a float bowl out od adjustment issue. did you try pulling the choke to see if it runs better up the hill? if it does its a lack of fuel issue and most likey a float need to be adjusted, imo
Old Mar 22, 2009 | 03:40 PM
HeftyLefty's Avatar
Check for trash in the carb float bowl, water in same or water in fuel filter. You may have water in, or blocked vent tubes too, so check those. And a WAG, you may have water in your muffler, depending on the last time you played submarine with your quad.
Check for water in your airbox and filter too.
skittero
35
Mar 1, 2019 12:39 AM
neilbedwell
Nov 10, 2018 11:02 AM
njrider64
Jul 4, 2017 01:40 AM
hoopduerr
Jun 2, 2015 09:01 AM
May 27, 2015 11:15 AM
