Broken rear driveshaft on 97 Sportsman
Old Mar 22, 2009 | 06:10 PM
flopper24's Avatar
Default Broken rear driveshaft on 97 Sportsman
I have two 97 polaris 500's with the u-joints in on both ends of the driveshafts. Problem is I keep breaking u-joints or yolks every year already broke one this year been out once, everything is always greased, I was wondering if I could put newer rear shafts with the cv-joints to help with the problem, has anyone done this swap?
Old Mar 22, 2009 | 06:14 PM
eggenz7's Avatar
i think it requires getting the newer hubs also. there have beena couple of guys on here that have done a conversion (couldnt tell you which ones or what year models they were using) but i has been done on polaris models [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 22, 2009 | 08:52 PM
flopper24's Avatar
Thanks
Old Mar 22, 2009 | 09:42 PM
shreker08's Avatar
I had this problem on my old 97 sportsman i took some steel cable and bolted one end to the frame and the other to the lower a-arm. I never had this problem again. It only seemd to happen when the back tires came off the ground just my opinion
Old Mar 23, 2009 | 08:02 AM
teamplayer's Avatar
I just did this swap about a month ago on my 98. I had to replace the outter bearing housings along with the cv shafts and the upper a-arms and then slot the holes on the forward upper mount to fit the new upper a-arm. Get all your parts from a 98-02 sportsman 335-500 and they will work. I got all my parts from ebay for about $350. I would not think twice about doing this again, I have had no problems at all. I do have an extra set of upper a-arm if you need them. If you have questions, just ask.
Old Mar 24, 2009 | 05:21 PM
flopper24's Avatar
Do you still have your old rear bearing housing's? If you still do let me know flopper@pmt.org
Old Mar 25, 2009 | 08:58 AM
teamplayer's Avatar
email sent:[img]i/expressions/present.gif[/img]
Old Mar 25, 2009 | 01:56 PM
gaugedholes's Avatar
man i could really use the outter drive shafts for the rear let me know if u have them and if u would sell them please
Old Mar 26, 2009 | 09:29 AM
teamplayer's Avatar
I have both rear driveshafts, they both have new u-joints in them, however, one of them has the caps welded to the yoke (for strength) the other is okay. make an offer. email me at jabraham17@yahoo.com
Jmuddin284
Jan 19, 2026 07:16 AM
Sandman2.0
Jul 21, 2015 09:03 AM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
