sportsman 500 compression
Old Mar 25, 2009 | 08:41 AM
gaugedholes's Avatar
Default sportsman 500 compression
how much compression should a 96 sportsman 500 push??? think its time 4 a rebuild...i lost all the power...just did a head gasket after this a few hours after asome puttin around it lots it all even in low.....
Old Mar 25, 2009 | 01:52 PM
anyone???
Old Mar 25, 2009 | 02:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you might ned just a new cam as the older ones wore off lobes. i would guess at least 120 psi new but its guess a guess w/out looking.
Old Mar 26, 2009 | 09:21 AM
Kerbmonster's Avatar
with the auto decompression u should see 85 - 95 psi
if ur thinking about rebuilding, why not go with a 11:1 comp piston, the HO cam and carb as well, make it run way better
Old Mar 26, 2009 | 09:41 AM
teamplayer's Avatar
Where can I fond a 11:1 piston for a 98 500 sportsman?
Old Mar 26, 2009 | 10:25 AM
i was told by a mechanic here in town that it should be anywhere from 175 to 190psi??? is that right?
Old Mar 26, 2009 | 10:33 AM
thats not right with the auto decompression if it was 175 to 190 we would be replacing more starters then we already are and if u go to aaenperformance.com u can find the piston, made by wiseco, either std bore or .020 oversize
Old Mar 26, 2009 | 10:52 AM
i was told to put a compression gauge on it and hold the throttle wide open and crank it until the pressure goes up and stops....or cold it be the cam??? i just put a new head gasket in and the cam didnt look 2 bad...someone please give me some info it is appreacitated...thanks guyes!!!
Old Mar 26, 2009 | 11:44 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: teamplayer
Where can I fond a 11:1 piston for a 98 500 sportsman?</end quote></div>
500 stage kits
