What is this part?
Old Mar 25, 2009 | 01:37 PM
HuntRanchRider's Avatar
Default What is this part?
Having problems with my 2006 Sportsman 450 (electric start doesn't work and RPMs report incorrectly.) Started taking things apart to see if I could find something strange and I found this hose just sitting on top of the motor not connected to anything. Does anyone know where it goes or what it does?
Old Mar 25, 2009 | 01:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
looks like one on the vent hoses from the carb and its a one way check valve on the bottom. did you have the emc replaced on your bike yet?? chances are its a bad one since it controls alot of differnt areas of the bike. have a dealer run your vin for the recall if you havent yet.
Old Mar 25, 2009 | 02:59 PM
I did have the recall done (so I was told.) I'm still trying to figure out the started and I had another post on that.
So one end of this hose connects to the corroborator and the other? Is this a critical piece of the puzzle?
Old Mar 25, 2009 | 03:00 PM
I agree with Stendori. It's definetly a vent hose with a one way check valve. I would look for a shiny tube coming out of your carb. and see if it fits.
Old Mar 25, 2009 | 03:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: HuntRanchRider
So one end of this hose connects to the corroborator and the other? Is this a critical piece of the puzzle?</end quote></div>
the check valve end most likely doesnt hook into in anything. thats why its one check valve so nothing can get into it.
Old Mar 25, 2009 | 06:23 PM
I blew in the hose and air flows from the hose side to the valve but not from the valve to the hose. So just to be clear I attach the hose end to the carb?
Old Mar 25, 2009 | 07:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yep thats where i would say that hose goes and you have the air flow backward in the picture as the hose hooks on and the valve free hangs down.
Old Mar 25, 2009 | 07:57 PM
That's what I thought you were saying but if I blow in it the air only flows that way.
Old Mar 26, 2009 | 09:08 AM
Kerbmonster's Avatar
take ur front storage box off the four wheeler, and right by the steering post is where ur ecm mounts, i would make sure it is the silver colored ecm and not the black one and then check and make sure that they put the ground wire eyelets through the screw on the ecm
*5 J's*'s Avatar
HuntRanchRider - your write up doesn't match your air flow arrow on the picture. You say that air flows from the hose side to the valve but not from the valve to the hose - yet the picture show airflow from the valve to the hose?????
</end quote></div>
