Trail Boss Chain
Old Mar 26, 2009 | 09:06 PM
BACarithers's Avatar
Default Trail Boss Chain
I've been trying to tighten my chain on my 330 trail boss and i've loosen the 2 bolts and brake clamp as well and put a screwdriver in the hole through the sprocket to the bearing housing. What I dont get is when I move the atv the whole axle (housing and all) turn and the chain doesnt tighten up any. Please help
Old Mar 27, 2009 | 05:56 AM
ftwflh's Avatar
Jack it up and check the axle bearings.If they are good replace the chain
Old Apr 5, 2009 | 08:24 AM
Bfcnb's Avatar
The rear axle's mount is kinda like a cam. Loosen the mount and turn the axle mount until desired.
Old Apr 6, 2009 | 12:47 AM
CaptainQuint's Avatar
If it isn't sufficiently tight at the tightest adjustments you can sometimes take a link out. That will get you by until you can get a new chain.
That's one thing I hate about those chain machines. you're constantly having to mess with the chain tension.
U2OFlyer
Aug 5, 2015 12:46 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
95wolv
Jul 17, 2015 08:13 PM
