03 700twin stuck in reverse!!
Old Mar 27, 2009 | 06:57 AM
fishing28's Avatar
Default 03 700twin stuck in reverse!!
I have an 03 sportsman 700, no problems with this ever. use 4wd so i dont kick my ramps out putting it in my truck. went to take it out and ride at a friends and it owuldnt come out of 4wd. I tried going in reverese, neutral, park i tried going backwards then forwards. nothing works! the light behind the switch that lights up (AWD) does go on and off as you switch it back and forth. the back light doesnt come on like it should when the ignition is turned on. but when i hit the brakes it does light up then if this has anything to do with it. anyone deal with this before? thank you for your help!
Old Mar 27, 2009 | 07:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well since its actually suck in awd, it leeds me to think maybe the issue is the roller cage in the front end has broke which sometimes will do this but not always. its weird you would be getting eletrical issues using the brakes and making other lights as mentioned work. maybe check the wiring of these to rule out any issues of bad connections,corrsion or bare wires touching. just a thought.
Old Mar 27, 2009 | 10:10 AM
fishing28's Avatar
thanks, my speedo is out and actually my buddy i was riding with remembered and called me this morning saying when his was out they told him it can make your 4wd act up as it goes through the same sensor.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
Jackg17
Sep 26, 2015 09:30 PM
