Wiring diagram for 1987 bayou klf 300
I am looking for the wiring diagram for the ignition...having what I think is ignition problems it will run for 30 seconds and quit....I tried different coil and still the same thing...flywheel key is not sheered...valve timing is correct I think it is the igniter but not sure....is there a way to test the igniter? Is there any subsutution for the ignitor...it is a Hiatchi TID11-01A...any help will be greatly welcomed....it does seem to back fire through the carb sometimes while cranking..when you shut the key off it backfires through the carb...I have seen this exact symptom on the older Fords with the ignition module mounted on the distbutor..
i need the wiring diagrams for a 1988 kawasaki bayou 300 can anyone help
