clutch swap need help PLEASE
Old Mar 28, 2009 | 05:45 PM
clutchman's Avatar
Default clutch swap need help PLEASE
i have a 07 sportsman 450 4$4 i need to know if other clutches from other mod will interchange and if you have to use the old springs and weights from the original clutch. Thanks for any and all info
Old Mar 28, 2009 | 06:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
looks like it will interchange w/ a few differnt models including springs and weights. this is according to the polaris site. now i know the 06's were not ebs clutches but not sure about the 07's. you shoud be able to put a 500 clutch on for around the same years to 09' i think. in any case just compare the spring and weights w/ the one you pick up and interchange if need be. imo
Old Mar 28, 2009 | 08:48 PM
clutchman's Avatar
thank you for the info,im new to the automatics and polaris. see alot of clutches on ebay but not for a 450. CCCHEAP thanks again.
Old Mar 29, 2009 | 07:41 AM
ftwflh's Avatar
IF it is non EBS ANY clutch will work as long as you use the correct spring and weights.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
