polaris electrical problems
Old Mar 28, 2009 | 10:00 PM
zombie's Avatar
Default polaris electrical problems
Hope someone can help.....My battery recently went bad after 4 years so i replaced it. Now the atv starts perfectly but my battery indicator and the speedmeter needle are flashing and my low and high beams do not work however my rear utility lights do work when i turn them on. If anyone has any ideas as to what might be wrong I would appreciate any advice..............................Thanks
Old Mar 28, 2009 | 10:35 PM
Douginmichigan's Avatar
Zombie
Start with the cheap check first, grounds. Like you said it's been 4 years.
Good Luck,
Doug
Old Mar 28, 2009 | 10:48 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Did you have the ECM recall done?
....Caper.......
Old Mar 29, 2009 | 01:21 AM
curby's Avatar
run the diog mode see if the thing is charging should be 14. - 14.5 at idle, i just went through this myself
Old Mar 29, 2009 | 06:41 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
....Caper.......</end quote></div>
have a dealer run your vin# to check if the ^^^ is recalled on your bike.
Old Mar 29, 2009 | 10:01 AM
zombie's Avatar
yes i had it replaced early last year when i got a recall letter
Old Mar 29, 2009 | 10:40 AM
zombie's Avatar
did you end up replacing anything? and did it correct the problem?
ripperray
Oct 10, 2023 02:42 AM
green giant
Jul 13, 2017 12:07 PM
txkevin
Sep 21, 2015 02:02 PM
DOAinNY
Jun 11, 2015 10:34 PM
TJM
Jun 11, 2015 01:28 PM
