lift kit...
Old Mar 29, 2009 | 09:01 AM
HARLEY_OWNER's Avatar
Default lift kit...
im looking at this lift kit on ebay.. its 2 in the front 1.5 to 2 in the rear... is that bad for the drive shafts or cv joints..? any help would be sweet
Old Mar 29, 2009 | 09:03 AM
Default lift kit...
also.. when you do a lift... that raises the frame rite?
Old Mar 29, 2009 | 09:07 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default lift kit...
Are you adding larger tires?..................The angle will change on you axles and shafts.......This can cause excess strain and wear on the parts....IMO...........yes you will gain ground clearance.....Caper......
Old Mar 29, 2009 | 09:08 AM
Default lift kit...
Forgot to say some riders buy the extra strong Axles and cv joints for the mod........Caper.....
Default lift kit...
no i wouldnt be puting tires on till next year... so 2 inches front and 1.5 back would put enough strain on it to damage stuff?
Old Mar 29, 2009 | 09:12 AM
Default lift kit...
All I know is the Angle will change and it will all depend on the way the Quad will be used..........Someone with more info and that has a lift done can tell you the trouble/problems that may develop.....Caper..................
Most post I seen with lifts though involve much larger tires .....Then adds more rolling weight..!!!
Old Mar 29, 2009 | 05:58 PM
EFF_Rubicon's Avatar
Default lift kit...
i have the gorilla lift and axles. the cv joint from gorilla
can handle the extra strain that comes from the lift.
i had a boot tear on me and it ran dry for not sure how long i just pulled
the axle to replace the boot and the cv is still in good shape. IMO they
are worth the extra money if you plan on lifting.
Old Mar 29, 2009 | 06:05 PM
700 sportsman's Avatar
Default lift kit...
Tim you could check out the high lifter forum, they are all about lifts, they could answer all of your questions
Old Mar 31, 2009 | 05:54 PM
switzomatic's Avatar
Default Lift
You can do the 2" lift with no problems. You will have to do a little grinding on the front struts(should be in the instructions) for cv boot clearance. Depending on what size tires you plan on going to it would be a good idea to invest in a set of Gorilla axles. I did the two inch lift on my old 02 700 Sportsman and went with 27" tires and stock axles. Mudded the living death out of it and never had any isuues.
Old Mar 31, 2009 | 05:58 PM
Default Lift-Gorilla Axles
If you really want to go for broke buy the Gorilla 6" lift with axles. Had that on my 05 800 and it totally rocked! The folks at Gorilla are great to work with. Only issues I ever had with the system was having to occasionally replace cv boots when they would get torn.
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Aug 5, 2015 05:55 PM
