Sportsman 500 H.O Help!!!
i have an 03 sportsman 500 ho and its been sitting for like 7 months now and a while ago gas was leaking out and i lost my key and my mom found it lastnight so i was trying to start it this morning and the battery needed to be charged and its a new battery bought that a while ago and i noctied the gas wasnt leaking anymore but it wont start someone help
And i got a new spark plug in there
http://s404.photobucket.com/albums/p...t=MOV00965.flv
does it have gasoline in the fuel tank huh? does it have a choke? use the choke.
with your finger hold the finger throttle wide open and then start it. if all of that has been done. open up the air box and while starting the atv spray starting fluid at the air filter and it should start right up. if you need to take out the air filter and lightly spray with starting fluid. keep throttle fully opened.
THe needle and seat are probably bad in the carb, is the crankcase full of gas? oil overfull? If so ghangge the oil and filter. To prevent this turn the gas off when not in use.
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
cdstang
Aug 31, 2015 07:52 AM
