Progressive Springs SP500
Old Feb 13, 2001 | 01:34 PM
2000SP500's Avatar
Has anyone put progressive springs on their Sportsman? Do they give you any lift over stock/ over lift kit? If it will work I would like to get rid of the lift kit bushings and replace with the adjustable spring setup. Can you load machine without as much sag a with stock springs? I am considering progressive springs at all 4 corners.
2000 Sportsman 500
27" Mud Bugs OUTSTANDING TIRES!!
ITP Aluminum wheels
K&N Filter
Old Feb 13, 2001 | 02:09 PM
rangerchet's Avatar
I put the progressive lift springs/cams on my 2000
xpedition 425 cc 5-speed. The eliminate the sag and give some lift. They should work the same on a
sp500. They eliminated my tire fender rubbing that
I had with 26 inch mudbugs. rangerchet
Old Feb 13, 2001 | 07:56 PM
cokeisit's Avatar
I have progressive springs with the cams on mine. didnt lift it any just gave you the ability to adjust the rate of the spring for hauling loads or putting on a plow. just like the rear has.
speedbuff
13
Nov 11, 2020 10:16 AM
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
4464
Aug 21, 2015 01:46 AM
Mphillips
Jul 2, 2015 07:20 PM
