KLF 300 Running Problem
Old Apr 1, 2009 | 06:50 PM
Funeral Home guy's Avatar
Default KLF 300 Running Problem
I have a 96 KLF 300. I can crank it on Choke but it will not run at all off Choke. Any Ideas? The carb has been cleaned
Old Apr 1, 2009 | 07:27 PM
jeffeosso's Avatar
too lean.. if it runs on choke, its running rich
Old Apr 1, 2009 | 10:00 PM
Ok so how do i adjust that? Is that going to be the Air\Flow screw?
Old Apr 2, 2009 | 06:42 AM
jeffeosso's Avatar
yes sir.. when the carb was rebuilt, there's the mixture or air/flow (doesn't matter what you call it) that needs to be about 2.5 turns out of closed.
its on the bottom, closest to the "intake" and should be the center scrwe, under the outlet side of the carb, NOT inside the bowl.
should turn it closed, firm, not hard, and then back out 2.5 turns.
wildbill59
Jun 9, 2015 02:28 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
blaze_master
May 26, 2015 11:18 AM
