Re-jet worth it?
Old Feb 13, 2001 | 01:55 PM
2000SP500's Avatar
Is it worth re-jetting a 2000 sportsman 500 with K&N filter? Any increase in power? Any other ways to give more power under $400.
2000 Sportsman 500
27" Mud Bugs Awesome Tires!!!!!!
ITP Aluminum wheels
K&N filter
Old Feb 13, 2001 | 10:16 PM
NewDSLover's Avatar
If you install a K&N, you should rejet, if you don't you might be running lean and risk piston failure. After installing your filter, do a plug test. Check and see if it's white/tan/black. This will let you know if you need to rejet. A good mod under $400 is a clutch kit or pipe or just a slip-on muffler. The pipe or muffler will add more hp's, and the clutch kit won't add any hp's but will get it to the ground better. Good luck and the best advise I can give you is read......everything you can about hop-ups for your quad.
Old Feb 24, 2001 | 04:18 PM
tjschmi1's Avatar
Just put a HPD aggressive clutch kit, and a K&N power kit in. Will do 62mph, before 56mph. Raced a 01 sp500HO, could not pass it, but he could not pass me either. Both mods cost around $250.
Tim
Old Feb 24, 2001 | 05:36 PM
seacow's Avatar
What # main jet is in the K&N kit?? (for the stock SP 500)
Old Feb 25, 2001 | 04:49 AM
samurai's Avatar
What is the K&N power kit? Something else besides the filter?
kodiacrunner
Oct 4, 2015 11:52 AM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
