500 H.O buy 1 get one free?
Old Apr 5, 2009 | 02:14 PM
jes Si's Avatar
Default 500 H.O buy 1 get one free?
I am relacing the bearing & seals on front drive and I am puzzled at this point cuz the strut hub replacement bearing & seal kit comes with 2 seals (1 kit per axle) and the strut housing only had 1 seal (in the back) . The only thing I can thick of is that I should double up or stack both seals. The original seal was definitely thicker & the seat appears to accomadate both the new seals since they are alot slimmer.
Am I wrong?
Old Apr 7, 2009 | 12:19 AM
MrMarty51's Avatar
Does the old seal have two lips???
If so check which way they are facing and install both seals accordingly.
Usually the inner seal will have the lip facing to the inside to seal lubes in and the outer seal with the lip facing to the outside to keep dust,dirt and moisture out.
Let us know.
Old Apr 7, 2009 | 04:01 PM
jes Si's Avatar
Let us know.
Thanks for the reply MrMarty51 ,
Problem is, this newbie threw out the old seals before comparing.
The only thing I remember about the old seal is that it was housed in painted metal with the lip out.
Old Apr 10, 2009 | 11:36 PM
jes Si's Avatar
turns out - according to an atv mechanic who specializes in sportsmans said that he didn't know why Moose packs 2 seals but he only uses one from that kit.
bmxatv10
Oct 14, 2022 06:23 PM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Lou Domenech
Sep 11, 2015 06:35 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
