KFX 400 reverse works TOO MUCH!
Old Apr 10, 2009 | 12:28 AM
tchandler91's Avatar
Default KFX 400 reverse works TOO MUCH!
i have 2004 kawasaki kfx 400. I have been having reverse problems with it. i need help bad. it is frustrating me beyond my limits. Usually i would have to have the quad in gear/neutral then turn the reverse **** and then kick the shifter down to engage the reverse. BUT.... instead now if i shift down past first it will automatically throw my quad in reverse without having to turn the ****. I took the reverse **** and cable off and the same thing happens. so i have no idea what to do. please help. thanks
Old Apr 10, 2009 | 12:49 AM
Default reverse broken
help?
Old Apr 10, 2009 | 07:45 AM
lorenzo42069's Avatar
if this fourwheeler is like the mojave than there is a little pivot that the reverse cable connects too it could be stuck. if thats not the case then you may have a broken shift drum which means you have to split the block and its in the middle of the trans and its quite a job to say the least. i just put one in my fourwheeler last week because it was goin into reverse all the time when i shifted down just like yours. hope this helps
Old Apr 10, 2009 | 10:04 AM
thank you for the reply. i did check the pivot thing you talked about and it seems to rotate fine. so i guess i would have to split the block and i cant do that. i am not a mechanice. well thanks for the reply
Old Apr 10, 2009 | 01:29 PM
if you can grab that little rod that sticks out of the block and spin it without it shiftin into gears that means teh drum is broke for sure. yea i understand it is a real bitch to fix. im not an atv mechanic either but i have worked on cars all my life so i guess technically i am pretty well mechanically inclined.
Old Apr 10, 2009 | 07:42 PM
jeffeosso's Avatar
greab the shop manual and adjust .. one of my lakota's had a bent cable.. and would pop into reservse instantly on neutral..
adjust the cable
Reactant
Mar 30, 2022 02:08 AM
hugemoth
Jul 20, 2020 03:28 AM
Scottma518
Jul 10, 2015 12:42 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
