need help on bayou 185 ( fuel pressure probs )
Old Apr 12, 2009 | 07:58 PM
jokerjosh's Avatar
Default need help on bayou 185 ( fuel pressure probs )
i have a 1985 bayou 185 and i was wondering what the psi is on the fuel pump? it runs decent but when i get into the throttle, it bogs down. it does not matter what gear it is in. im thinking that its pumping fuel but not enough. thanks
Old Apr 12, 2009 | 09:30 PM
jeffeosso's Avatar
gravity feed, right? in 1985 i don't believe that there WAS a fuel pump on ANY atv
rebuild the carb
Old Apr 17, 2009 | 05:58 AM
jokerjosh's Avatar
it may not be an 85, but this thing does have a fuel pump. i don't want to sink alot of money in this wheeler because new pumps are expensive. i am considering putting in a universal car pump with a regulater. thats why im wondering about fuel pressure. thanks for any info
Old Apr 18, 2009 | 12:10 PM
rv's Avatar
rv
Default check your battry
my buyou had a similar provblem so replaced the feulpump with a cheap canadian tire special that only put out 6 psi and it helped but later found that the battery wasnt quite up to "snuff" so give your battery a check also .my bayou was an 87 i do recall but that shouldnt matter
COFatboy
May 2, 2020 12:06 AM
mtdewmn
Jan 19, 2017 12:13 PM
Aug 11, 2015 11:56 PM
toonces
Aug 5, 2015 05:55 PM
southbayman
Jul 24, 2015 09:30 AM
