2007 X2 Will not Ilde
Old Apr 18, 2009 | 11:08 PM
gdude's Avatar
Default 2007 X2 Will not Ilde
I have a 2007 500 X2 EFI . Runs great but will not start or idle without giving it a little gas. Any ideas? Can the idle be set up a little without putting in on an analizer?
Old Apr 19, 2009 | 02:32 AM
Might try to adjust slack in throttle cable,adjuster in rubber boot just below throttle housing. Must have 1/8" maximum slack at thumb throttle. Could be source of non idle issue. If idles ok,check that idle DOESNT go up when you turn bars side to side. If this doesnt help with idle then could be short in sensor(s) harness.
Old Apr 19, 2009 | 05:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its not the cable adjusting, then a dealer needs to put it on a computer to reset the idle right?
Old Apr 19, 2009 | 05:33 PM
gdude's Avatar
Talking
Old Polaris Tech hit the nail on the head.........thanks.....I made the adjustment myself and all is good......thanks again
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
ylomnstr
Sep 4, 2015 05:02 PM
