What have you done to shave weight on Scramblers?
Old Feb 14, 2001 | 10:55 PM
GE4x4's Avatar
I just want to know how you can lighten up a 500 4x4 as much as possible, and still have it look like a Scrambler.Is it possible to get it to the low 500lbs.
Old Feb 14, 2001 | 11:13 PM
Xplor's Avatar
Tough to do. Most people who are serious in putting there Scramblers on a diet go for the following: Starter elimination, oil injection elimination, lighter rims and tires, on older models replace steel with aluminum. You can add aluminum handle bars, drill holes in the chain guard,hmmmm...can't remember the others.
Some guys in here really lightened there quads by getting rid of every little thing that weighed something.
Old Feb 15, 2001 | 10:25 AM
EasterEgg's Avatar
Some of the simple weight reduction I have done is replaced the steel sprocket guard with a home made aluminum one and replaced the stock steel rear wheel hubs with aluminum ones. I`m even thinking of going to an aluminum rear sprocket but in the conditions I ride I`d be replacing it every season. I`ve concentrated on rotating weight more than overall for now. I don`t want to lose the major items needed to reduce a lot overall weight. As 3TV showed us in a different post losing 35 lbs makes as big a gain as a pipe though. Time to start thinking about other things. Like an aluminum battery tray with a smaller battery. HTH
98 Scrambler 500
00 Trailblazer 250
See my pic`s at http://www.picturetrail/riskracing
Old Feb 15, 2001 | 12:56 PM
jim's Avatar
jim
I changed modified or replaced the following to remove 50+lbs & could go another 20lbs if I wanted to start spending money. Short of expensive frames, tranny ect you can take off close to 70lb by changing the following: Pipe, muffler, floorboards,battery, starter, shifter, oil pump & resivor, fan, bumper/shrounding, all unused steel brkts & wiring/cables, tires, bars, rims, steering post, swingarm & a-arms to name a few. My pics might give you some ideas to try.
Jim Maloney 98 400 Scrambler
http://photos.yahoo.com/jim400scram
exmotocrosser
Sep 13, 2019 06:12 AM
Robinhood
Dec 26, 2015 10:28 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
