When Change to Synthetic
Old Apr 25, 2009 | 10:08 PM
ebx's Avatar
ebx
Default When Change to Synthetic
I have an '07 TRV LE 650H1 w/ 185 miles on it. It is completely stock. At the 100 mile service I changed the engine oil to dyno oil. What is the factory reccommended engine break-in before I can switch to synthetic? Thanks.
Old Apr 26, 2009 | 02:10 AM
swampyjunior's Avatar
There is some debate on that depending on who you talk to. From my experience your engine will kind of wake up between 500-1000miles. Both of my machines did and I still had dyno oil in them at that time. I now run the AC synthetic in the TRV as is seems to make the auto tranny run cooler. I still run the dyno in my 400.
I know guys who swear by changing to synthetic on the first oil change. I personally would choose dyno oil due to cost. I can change the oil on my 400 (dyno oil) for $25 including filter. It is closer to $40 for the synthetic oil with filter change. Still, frequent oil changes are far cheaper than an engine rebuild.
I think the factory reccomended engine break in is 10hours or 100miles. Most AC mechanics will tell you that you can switch to synthetic then if you want to. But, you can NOT switch back and forth between dyno and synthetic.
SJ
Old Apr 26, 2009 | 09:00 AM
cupsz71's Avatar
Talking
I ran my '08 TRV 650H1 to 350 miles before changing to AC's Synth oil. Not sure if it's the fault of the oil or not - but i found that the oil was 20w50 - too heavy for the extreme cold here in ND. & that may have been the reason I blew a stator seal in late Dec '08, and had to get it fixed.
I just recently switched to AMSOIL 0w40 ATV wet-clutch synth at 650 miles w/K&N oil filter.
Also both my diff's are AMSOIL 75w90 synth.
My "plan" is now change every 500miles and the diff's every 1200.
Hope this helps
my2¢
Old Apr 27, 2009 | 09:27 AM
Rude Robert's Avatar
why cant u switch from synthetic to oil and back?? never heard of that
Old Apr 27, 2009 | 09:44 AM
cupsz71's Avatar
It has to do with the oil "molecules" and how they bond/adhere to the metal & rubber (seals) in the motor and how heat is dispersed thoughout.
I heard of people switching back & forth and they've suddenly got a leak or an oil consumption issue.
Not sure why they sell BLENDED synth w/no seemingly ill effect, but the 'DON'T GO BACK" rule is something I've followed for yrs.
my 2¢
Old Apr 27, 2009 | 11:40 AM
oops well the dealer didnt have any syn oil left so i went with the duel blend now what do i do
Old Apr 27, 2009 | 03:45 PM
Moverlie's Avatar
What is dyno oil? I'm coming up on the 10 hr mark and looking for some maint advice. thanks..
Old Apr 27, 2009 | 04:16 PM
Moverlie,
The dyno oil I am refferening to is the regular oil with additives for 4 stroke ATV's sold by Arcic Cat like 10w-40 or 5w-40. AC also makes a synthetic oil (could be a blend I don;t know for sure) that is 0w-40.
Also, you can save a bundle of $ over time by switching to an automotive oil filter for a 400 500 AC. I think I pay like $3.99 US for a filter instead of like $10-$15 for an AC filter from the dealer. I also save a little $ by buying oil and filters by the case. I normally end up changing the oil about every other month. That 500-1000miles adds up fast! I usually put 100-200miles on each weekend during the summer.
My reasoning for not switching back and forth is due to exactly what Cups said. It "can" lead to oil leaks and or oil consumption by the engine. Although I know engines that have had one or the other in them from the get go and never switched that had the same leaks and oil consumption. I was told at one time it is also due to some of the oil additives in the different types of oil not being compatable. They basically react with each other negatively and it keeps the oil from doing what it is supposed to and your engine wears excessively.
SJ
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
Sw00p
Sep 24, 2015 02:50 PM
