p650 wont start
Old Apr 28, 2009 | 03:33 PM
prariemudder's Avatar
Default p650 wont start
my p650 sat over the winter and now it wont start, acts like it wants to but will not start. also i dont know if this is related but the multi-function meter is not displaying anything
Old Apr 30, 2009 | 11:47 AM
Joebear's Avatar
Check the battery connections and the grounding point at the frame. Battery needs to be good too.
Change out your fuel and drain the carbs.
Old May 6, 2009 | 03:18 PM
Hayashi's Avatar
Engine not starting and Meter showing blank are two different problems. The 650 will start and run even with the meter disconnected from the quad.
Your battery should be fully charged 12.8V or higher.
Set at full choke.
Do NOT open the throttle.
Install fresh plugs.
Crank 5 seconds, rest 5 seconds, crank 5 seconds again. And repeat until fires up.
Old May 10, 2009 | 10:23 AM
trailblazermudrunner's Avatar
ikn with my p360 is a diffrent set up but if the battery is bad the oil netural and revers light wont work if its bad it could just be your battery
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
