500 ATP swingarm R&R
Old May 1, 2009 | 08:26 PM
HSR's Avatar
HSR
Default 500 ATP swingarm R&R
Pulled the rear swing arm on my 04 500atp to replace the rear u-joint.Now I need the torque specs or replacement procedure for tightening the threaded pivot pins.Anyone have a manual???
Steve
Old May 2, 2009 | 12:42 PM
Apply loctite thread sealent to right side and left side pivot bolt and install both into the frame and swingarm. Torque right side pivot bolt to 120 ft. lbs. and the left side to 14 ft. lbs. Apply loctite to the exposed threads of the left side pivot bolt and lock nut. Reinstall rear shock bolt and torque to 25 ft. lbs. Reinstall gearcase vent tube. Install the brake caliper and torque the brake caliper bolts to 28 ft. lbs.
I wasn't able to copy the information from my cd so this is the best I can give you. Hope it helps out.
Old May 2, 2009 | 02:52 PM
HSR's Avatar
HSR
Default specs
Thats perfect Moose, appreciate it.
Steve
Old May 3, 2009 | 06:06 PM
You're welcome.
STLyamwar
Jul 25, 2020 04:44 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
95wolv
Jul 21, 2015 12:25 PM
Dabears1983
Jun 23, 2015 04:59 AM
