motor help!!
Old Feb 15, 2001 | 03:10 PM
shooter69's Avatar
here is the story 94 400L 4x4 I was at the races this weekend pulling my friends car after a run I went down to the other end to pull him back about half way there it started to sputter and then started pouring out white smoke from the exhaust at this point it was still running I got it back to my truck and noticed the pipe at the back was very hot .when we got to the house it would not start but it spun over freely. I have been out of town all week and have not even got to pull the plug out yet to look at.
I don’t know a whole lot about 2 stroke engines so I need help does this sound like an oil injector putting in to much oil or something more serious ?
Any help would be great!!
sorry it is so long
Old Feb 15, 2001 | 05:14 PM
scr500's Avatar
Sounds more serious.Possibly a hole in a piston.Do a compression check.
Old Feb 15, 2001 | 05:19 PM
bubba1005's Avatar
you may have also blown a head gasket. If it is liquid cooled. White smoke usually means antifreeze.
Old Feb 27, 2001 | 01:33 PM
shooter69's Avatar
did a compression check an it was 120 PSI sono hole in piston ar blown head gasket now what?
Old Feb 27, 2001 | 03:38 PM
Harold's Avatar
smell of your exhaust, does it smell sweet like antifreeze?????? BINGO!!!!!!
Old Feb 27, 2001 | 08:27 PM
NewDSLover's Avatar
A little while ago I let me brother ride my 400 2x4 and had problem with it like your having. I also did a compression check and there was alittle over 110 psi. Pulled the head and there was a melted rings to the piston. This will seal enough air to give compression but not enough to run the engine. Easy enough, pull your bottom water hose then pull the 6 head nuts and look. If nothing else you'll need a head gasket and some 50-50 mix. But most likely you'll find a piston/rings issue. Pull your jug and take it to your local shop and ask for a Wisco and have them bore it out. Order a top end gasket kit and reinstall. Not more than a few hours of work for you, a day or two to get it bored. Good luck, wish I could be there to help. Love them 2 strokers!
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
