"belt" warning light on brute force ??
Old May 3, 2009 | 08:10 AM
dugpor's Avatar
Exclamation "belt" warning light on brute force ??
the belt warning light is lit on my 06 brute force, I do not have the owners manual. does this mean there is water in the housing or that the belt is worn out ???only has 700 miles on it. it came on right after I got stuck in a water/mud hole.
Old May 3, 2009 | 09:14 AM
TLC's Avatar
TLC
You may have to do the "Procedure" as it is called.
Read and learn. http://forums.atvconnection.com/kawa...elt-light.html
Old May 3, 2009 | 09:29 AM
miiller's Avatar
Yep its an easy fix, you can do it yourself.
Old May 5, 2009 | 04:50 PM
dugpor's Avatar
Smile
Thanx guys, sounds like a pain in the butt, beats getting taken at a local dealer..time to scrape some knuckles !!
Old May 6, 2009 | 09:47 AM
Hayashi's Avatar
TURNING OFF "only" is not the real fix. It's like CHECK ENGINE light comes on your car and you are putting a piece of black tape on it.
There is a reason why the the light came on. You need to find out why and DO something about it. Then, the final step should be TURNNING OFF the light.
ylomnstr
Sep 22, 2015 12:19 AM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
ylomnstr
Sep 4, 2015 05:02 PM
