Help with the predator (camber)
Old May 3, 2009 | 11:44 PM
Predasaurous's Avatar
Default Help with the predator (camber)
hi i have a 07 Polaris predator 500 and have noticed my wheels were out of alignment so i replaced the tie rod ends and then re aligned it , but noticed the camber is differnet from the left and the right.
so i was wondering what would cause the camber to be out i have checked the ball joints are not warn out, and the spindle is not bent
and also is the camber suppose to be 90 degrees to the ground or toed in or toed out
oh and i cant afford to take it to a shop thanks.
Old May 4, 2009 | 06:02 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
im gueesing on this, but they both should be the same camber . is the shock set right or meaning is the set up the same lettting one side setting down letting it camber in?? just an idea if nothing is bent.
Old May 4, 2009 | 07:28 AM
Kerbbirds's Avatar
Something is either bent on that side or the spring is weaker on that side.
Old May 4, 2009 | 10:37 AM
shocks are both adjusted to the same (eye to eye is the same)
so is it suppose to be a negative camber or positive or neutral
thanks for the responses so far
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
1966F100
Jul 12, 2015 03:08 AM
