'87 250x left engine cover crack
Old May 7, 2009 | 11:51 AM
ironcowboy's Avatar
Default '87 250x left engine cover crack
Well since i bought my 250x this year, its always leaked oil, but its been getting worse, so now I cant even take a long ride without fear that i'll run out. I took the left side engine cover off and i can see where it was cracked up (from the chain i guess) and someone JB welded it. But i guess it will need some major work or replacement, i can try to remove all the JB weld and re glue it, but i'll need a gasket or something that i can seal it with. Or i could just replace it. Any suggestions? I cant ride till i get this fixed...
Old May 7, 2009 | 01:04 PM
budedm's Avatar
I found this on ebay for you. If I were you, I'd clean it and JB weld it again. Then buy a cover off ebay and if the JB doesn't hold, , you've got plan B. But JB is usually pretty good for that case job.
eBay Motors: 1987 honda trx250x left side engine magneto cover (item 320368348616 end time May-12-09 16:21:49 PDT)
Old May 7, 2009 | 01:42 PM
ironcowboy's Avatar
Thanks for the help, i'm going to try JB and a new gasket for now and if that doesn't work i'll pick up a new cover.
Any tips on cleaning all the oil off it so the JB wield sticks?
Old May 7, 2009 | 10:15 PM
hexen71's Avatar
i wold use brake clean and a wire brush to clean the case
Old May 8, 2009 | 05:30 PM
ironcowboy's Avatar
I ended up using orange clean. I was out of brake cleaner. Will see how it holds. I think a new gasket will fix it up though...
Old May 8, 2009 | 11:51 PM
hexen71's Avatar
as long as you got all of the oil and grease off you should be fine. jb weld should hold up fine i just used it to patch my transmission pan after a rock took it out
MikeyBoyesq
Nov 27, 2020 02:44 PM
wannabe32
Jul 7, 2015 11:30 AM
bikedad3
Jul 2, 2015 02:15 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
bucklove007
Jun 8, 2015 07:28 PM
