Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Which way to turn pilot jet to run richer?
Old May 13, 2009 | 11:14 AM
budedm's Avatar
Default Which way to turn pilot jet to run richer?
Honda 300EX. I want to run richer. Should I turn it in or out?
Old May 13, 2009 | 12:28 PM
95wolv's Avatar
Just to be clear, not raggin' on you, but the pilot jet is the small,long jet inside the carb bowl, in front of the main jet. You are referring to the idle mixture screw, and to answer your question,turning in will lean it, out will make it richer. Start at about 1.5 to 2 turns out and go from there. If you have modded you intake or exhaust at all, you may want to go up one size on the pilot jet, it will start and idle better,especially when cold.
Old May 13, 2009 | 08:27 PM
budedm's Avatar
Yes, the idle mix jet is the one I mean. Thanks.
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
