Looking at 2005 Rubicon
Old May 13, 2009 | 07:26 PM
corbyzz's Avatar
Former Sponsor
Default Looking at 2005 Rubicon
2005 Rubicon 112 miles 12 Hrs, what should I look for. The quad appears to be brand new. I am having a buddy pick it up for me because I can't. With this low of miles I would think it is o.k. Any advise would be great.
Old May 13, 2009 | 09:06 PM
mbogosia's Avatar
Have him open the air filter box and take a peak. Just to make sure its not full of mud. Also, look at the front cv boots. Have the owner take off the left side plastic and let your friend check the engine oil.
Old May 13, 2009 | 09:13 PM
corbyzz's Avatar
Former Sponsor
I think I may drive down and get it myself just to be safe.
Old May 14, 2009 | 09:00 AM
Turfguy's Avatar
If its clean, that will be a great quad for many miles.
Old May 14, 2009 | 10:43 AM
JeffinTD's Avatar
Do the obvious. Make sure the frame and A arms are straight, no mud in airbox is a good idea, make sure it runs right and shifts properly in all modes.
The thing is practically new, though, so unless it's really been abused I'd expect it to be fine.
I think I put more miles/hours on my Rincon than that the first day I took it out.
Old May 14, 2009 | 08:17 PM
corbyzz's Avatar
Former Sponsor
thanks for the advice guys. Everything looks good the bike is great expect he cross threaded on of he bolts on the plastic engine cover on the bottom. He told me he changed the oil once, when asked if he used Honda oil he said yes. For some reason I didn't really believe him....it now has Honda oil in it and a new filter. Bike will not idle unless the choke is pulled out slightly. I think it just has old nasty gas in it. I am going to my property tomorrow to put it too the test. What should I expect from the tranny. Will it be able to break the tires loose? Pull Wheelies? so far I ran it around the neighborhood and sometimes it will snap to it quick, and other times it feels a little lame. Could this be the dirty carb/gas?
Old May 14, 2009 | 10:52 PM
JeffinTD's Avatar
A rocket it isn't. Not idling w/o the enricher on would tend to indicate the carb needs removed and cleaned.
Old May 15, 2009 | 06:17 AM
mbogosia's Avatar
Yeah, I have been a bit dissapointed with my Foreman as far as snap off the line. I mean, it goes fast enough and it pulls up any hill I ask it to. But as far as just pulling wheelies at will it just doesn't. Although I only have around 100 miles on it so maybe it will break in down the road.
I would try adjusting the idle at the carb. There should be a small screw that has a spring under it. Turn this in a bit with your hand and your idle will come up.
Old May 15, 2009 | 11:06 AM
corbyzz's Avatar
Former Sponsor
cleaned the carb, and still won't idle??
Old May 15, 2009 | 05:40 PM
JeffinTD's Avatar
Are you sure you hit every port inside the throat, and every passage with carb cleaner?
Might also be sure you don't have an air leak between the carb and head.
