Ticking Noise = Valve Adjustment
Old May 14, 2009 | 02:20 PM
Pakman's Avatar
Default Ticking Noise = Valve Adjustment
I have a ticking noise coming from my Foreman and I looked threw some of the older threads and nothing went in too deep on how I would go about adjusting the valves to correct this issue. Do I adjust it after the quad warms up or do I do it when she is dead cold?
And is this really that big of a problem?
Old May 14, 2009 | 02:34 PM
budedm's Avatar
Cold. And yes it can cause problems if you don't maintain valve adjustment.
Old May 15, 2009 | 11:37 AM
Pakman's Avatar
I have yet to go through my manual, but I am thinking (tell me if I am wrong) that I should tighten the valves to rid myself of the "ticking", and of couse turn the screws a half turn at a time or even a quarter turn at a time?
Old May 15, 2009 | 12:32 PM
budedm's Avatar
Not sure how the Foreman work but on my 250X, I loosten a locknut on a screw that goes through the rocker arm. The bottom of the screw meets the top of the valve stem. I rotate the crank so that the valves are both closed, then screw the screw toward the valve stem until there is .004" clearance, measured with a feeler gage. Then tighten the locknut up without moving the screw. It's an easy 30 minute job for me. Even on your Foreman, I'm sure there is no "tighteneing of the valve itself". It's a DIY job no problem.
Old May 15, 2009 | 04:07 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
See pg 96 of the June ATV Action Mag.
Divergent12
Dec 30, 2017 08:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
