Banshee help please
Old May 26, 2009 | 07:08 AM
bansheerider44's Avatar
Default Banshee help please
I have a banshee and I had it for 3 days and a ring feel off so we did a top end job and it ran good after that but I can't keep antifreze in it I don't know were it is going it runs awsome but it just won't keep aintifreze in it the ratiator is empy
Old May 26, 2009 | 11:50 AM
91Warrior357's Avatar
youll have to pay attention to where it seems to be leaking from, hopefully not from the headgasket lol.
Old May 26, 2009 | 01:08 PM
ya i know man but the thing i dont get is i just did a top end job on it thats why i dont see how it can be getting into the cylander or anythuing liek taht becasue we put all new gaskets into it do u think there is a posibly that one of the hoses are leaking or are cracked what other ideas do u have
Old May 26, 2009 | 09:59 PM
brokemybanshee's Avatar
If you see alot of white smoke it could be leaking in the cylinders. Other than that it should be pretty simple to figure out where its leaking from, its not like theres really much to a banshee so spotting something leaking should be easy, IMO.
After you rebuild you'll need to fill the radiator w/antifreeze and then after you start it, turn it off and you'll need to fill it up again, keep repeating until the entire system is actually full because of the vacume, not just the radiator. You might need to start it with the radiator cap off (make sure its cold before you try that) and see if that helps suck the antifreeze into the system.
Pretty easy machines to figure out though, look close.
Old May 26, 2009 | 10:40 PM
ok man i will try that tommow and if i do that when it is cold is it going to leak out the radiator or anything liek that lol and i dindt tell u but before we did the rebuld it was smoking out that jug so then it was buring antifreeze but now it dont smoke at all or just alittle liek thaey should ill try that though thanks and not to get off the subjet but my frineds said that this will ony go 55 i said ya right jw what u have to say about that
Old May 26, 2009 | 11:11 PM
stock banshees hit around 65-70 stock depending on how long u dare hold it wide open lol, with a few mods they can reach 80s pretty easy.
Old May 27, 2009 | 11:07 AM
ya ok that it stock lol hahaha not for to long u dont want to hold it open hahaha but idk how it could be leaking into the cylanders with a new top end enless the jug is cracked but i would think the macinic would have seen it
Old May 28, 2009 | 11:03 AM
anyone else got any ideas
Old May 28, 2009 | 10:45 PM
Yeah it will leak out if theres a hole in the line/radiator.. dude seriously... good luck with your banshee..
Old Jun 2, 2009 | 03:16 PM
superyfz350's Avatar
Top off the coolent after every time you get it out. You cant fix the leak if you dont know where it is, so be sure to check everywhere. After i rebuilt mine I frogot to tighten down the coolent drain bolts on the sides of the jugs, so check them. Its highley unlikely that you cracked the jug. Just keep the radiator and resovior toped off, and check for leaks
