Fan won't work on a BF 750
Old May 26, 2009 | 06:32 PM
owtlaw jason's Avatar
Default Fan won't work on a BF 750
I have an '05 750 and the fan will not kick on. I have pulled the wires off the temp sensor in the radiator and jumpered the contacts and still nothing. I know the fan works because I can jumper from the battery to the fan and it will work. Is there a relay switch somewhere that I need to be looking at?
What am I missing?
Thanks in advance for your feedback
Jason
Old May 26, 2009 | 07:12 PM
miiller's Avatar
Hey man yes there is a breaker underneath the seat. Mine just broke off, you should check yours and see if the button needs reset or if your contacts broke off like mine. And I just ordered one from this website. This will also show you where it is at.
CheapCycleParts.com's 2005 Kawasaki ATV Brute Force 750 4x4i (KVF750-A1) Parts List
part number 21008
Old May 26, 2009 | 07:59 PM
I checked the fuse. It doesn't appear to be tripped. I am getting no power to the fuse, I checked with a test light.
Old May 27, 2009 | 10:15 AM
Hayashi's Avatar
Check the rear BUS connector for corrosion.
Do a search for more detail.
Old Jun 3, 2009 | 07:35 PM
JDSpud's Avatar
Hayashi hit the nail on the head my buddy with a 750 has the same problem
Old Jun 6, 2009 | 09:52 AM
KMKjr's Avatar
Yep, happens to them all!!
Old Jun 9, 2009 | 03:08 PM
Hayashi's Avatar
Not really. This problem does not happpen on newer EFI BF750s because the subject BUS connector does not have the (+) and (-) wires together anymore.
Old Jun 11, 2009 | 10:16 PM
rv's Avatar
rv
the same thing hapened to my 05 650 the connections under the seat were coroded and i put sone grease on then and its been good ever since
Old Jun 12, 2009 | 10:01 AM
KMKjr's Avatar
My bad, I'll clarify.
Happens to most before EFI.
BTW, your sig is too true!!
Old Jun 30, 2009 | 03:51 PM
DR. PHIL's Avatar
Also the fan breaker is a little box all by itself under seat, not inside fuse box, it has a little green button sticking out of it if it is popped, push it in so the top of the button is flush, the fan will work now.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
