400EX Compression Check
Old May 30, 2009 | 04:40 PM
Falconman's Avatar
Default 400EX Compression Check
I recently checked my stock 03 400ex with a compression gauge and got a reading of 70-75 psi. Is this good or does it need some help? What should the compression be? Thanks.
Old Jun 1, 2009 | 06:18 PM
blackngold1982's Avatar
it should be bvetween 100-128 psi
Old Jun 1, 2009 | 09:04 PM
Rkangel777's Avatar
Also, make sure you hold the throttle wide open when checking the compression, otherwise you could get false readings.
BTW my compression tester only has fittings for the two common automotive sized plugs. Anyone know who carries just the fittings or adapters that will fit the EX?
Old Jun 2, 2009 | 12:09 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Be aware also that some engines have decompressors, to aid in hot starts. If your engine has one of these, you will need to do the type of test where air is pumped into the combustion chamber under pressure, and you wait to see if it holds (rather than cranking the starter or kicking it over).
Old Jun 3, 2009 | 06:31 AM
gsjeepxr's Avatar
i believe mine is sun-pro. got it at pep boys as a kit for 40 buks. you can probaly just order the adapter your after. maybe search it online.
Old Jun 3, 2009 | 06:46 AM
budedm's Avatar
"Be aware also that some engines have decompressors, to aid in hot starts. If your engine has one of these, you will need to do the type of test where air is pumped into the combustion chamber under pressure, and you wait to see if it holds (rather than cranking the starter or kicking it over). "
Or disconnect the decompressor cable like I have to do with my 250X.
slowgsxr97
Mar 18, 2022 03:40 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
ghost civic
Jul 19, 2015 10:13 AM
