dynojet kit?
Old Feb 16, 2001 | 11:57 PM
burbanator's Avatar
Whats the difference from the dynojet kit versus,the jets you buy at the cycle shop? Do you get the needle and spring with the kit and is it a noticeable difference from the stock needle and spring? If so is it worth the $60.00.
Old Feb 17, 2001 | 10:56 AM
DS650DAVE's Avatar
Yes I beleive it worth the money.You do get a new needle, spring,adjusting washer,E-clip,along with jet sizes 165 thru 200{8 total}.If you were to pay for all pcs.seperately would probably be more cost of kit.Kit comes with pamphlet for various set-ups,also can call 800 # for help/questions.Don't know if jets are same as stock{sizing}.
I also installed 2001 carb. updates{spring & cup}while I had the carb.off & apart.Tremendous increase in bottom end power& throttle response.Previously could lift front end from hole shot...NOW I can.
chop
14
Apr 26, 2001 03:02 PM
DSAPP
Jan 31, 2001 08:34 PM
nightlife7810
Oct 17, 2000 04:36 PM
CG400exMaster
Sep 25, 2000 12:17 PM
RVonSand
Dec 2, 1999 11:41 PM
