01 400ex smokes when started
Old Jun 1, 2009 | 07:50 AM
trail1's Avatar
Default 01 400ex smokes when started
My quad smokes a little when its first started then clears up when its warm. Something bad gonna happen soon or don't worry to much. I dont have to add any oil between changes which is once a month thanks.
Old Jun 1, 2009 | 08:15 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I would do the basic things like compression testing, to be sure it isn't the rings. But, valve guides are the first thing to go when this engine starts showing its age. They get worn and start passing oil. Not partucularly difficult to replace.
Old Jun 1, 2009 | 08:26 AM
budedm's Avatar
I agree with reconranger. It's probably valve seals. They shrink when they are cold, so oil gets past them and into the cylinder when you first start. But as the engine warms up, they expand and seal off. Nuttin to panic about but they will continue to get worse and then you may start fouling plugs.
Old Jun 1, 2009 | 10:12 AM
HeftyLefty's Avatar
Wait until you start using oil, then change them out.
Old Jun 1, 2009 | 01:32 PM
Red Rider
Running an oil that has a very high "film strength" (HT/HS or High Temperature/High Shear), can help seal rings and guides that are showing their age. I would suggest Maxima Extra, ester synthetic.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Bm400ex
Jun 22, 2015 09:16 AM
Jbird4681
Jun 9, 2015 01:59 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
