bayou 220 2x4 start problems
Old Jun 2, 2009 | 06:33 AM
festus191's Avatar
Default bayou 220 2x4 start problems
have a 220 bayou 2x4 motor runs as long as starter switch is held in but as soon as let off switch motor dies has anyone had this problem and what did you find
Old Jun 3, 2009 | 01:52 AM
07bloomfieldb's Avatar
Whe you say it runs do you mean it turns over, or it runs? Have you got a spark? How long since it was last used? Ever cleaned the carb / fuel lines / filter?
Old Jun 3, 2009 | 03:19 AM
festus191's Avatar
Default reply
it runs revvs up with throtle till let off switch lastestest update tried it agin now starts with pull rope but no starter op
Old Jun 3, 2009 | 10:16 AM
Hayashi's Avatar
Check the ground wire connection from the starter solenoid to the engine case on the LH side.
Old Jun 5, 2009 | 04:52 PM
Yeah, ground or bad solenoid probably. How old is the battery?
rcappie4
Jun 21, 2015 07:33 PM
jgreerberube
Jun 21, 2015 02:27 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
momofo
May 27, 2015 12:06 PM
