bad fuel pump 86 bayou 1885 and carb question
Old Jun 5, 2009 | 12:26 PM
benflynn's Avatar
Default bad fuel pump 86 bayou 1885 and carb question
my pump is out, and i was thinking of buying a generic pump that will support 25hp, anyone see a problem?
also, what is the method for tuning the carb? i am going to order a new needle and jet, it sat up and still runs a bit iffy after i cleaned it up before the pump went
all in all it is a great bike
Old Jun 5, 2009 | 02:53 PM
Hayashi's Avatar
Are you sure your 1885 got a 25 hp motor?
Isn't fuel gravity fed to the carb, not by a fuel pump?
If there is a pump, is it an electrical type or vacuum type or mechanically driven?
Old Jun 5, 2009 | 03:44 PM
benflynn's Avatar
the tank is down low, so it needs a pump, it has an inline electric pump, the cheap pump suports 25hp, and figured it would be more than enough
just any cheap inline small e pump
any word on carb tuning?
Old Jun 5, 2009 | 04:53 PM
07bloomfieldb's Avatar
I presume he means 185, but still could be a touch on the low side.
Old Jun 5, 2009 | 05:01 PM
benflynn's Avatar
185 for sure, 1986 klf185
Old Jun 5, 2009 | 08:52 PM
benflynn's Avatar
when i pulled the pump it was a Mr Gasket micro pump, so i got one off the shelf at autozone, it is a 35gph 4-7psi, overkill im sure, but it has to pull less amps than the old one going out, now i just need to know how to tell what jet and needle is in my carb so i can order an replacement
and how do i tune the fuel/air screws
green giant
Jul 13, 2017 12:07 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Shooterj2003
Jun 21, 2015 07:51 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
