Help....1986 fourtrax 250 hub
Old Jun 6, 2009 | 08:27 PM
jayb1982's Avatar
Default Help....1986 fourtrax 250 hub
I had a 1986 honda fourtrax 250 sittin in my back yard got it running mint but ran in to a little problem. front bearings are shoton left side. so i was wondering how u remove the cover over the brakes (hub). I took the axle nut. but the hub wont slip, just wondering if anyone can help
thanks
Old Jun 8, 2009 | 05:38 AM
HondaMechanic's Avatar
Old Jun 9, 2009 | 09:25 AM
jayb1982's Avatar
thanks the drum puller worked awsome, I was wondering if you knew a easy way how to remove the 2 bearing and collar from the hub
Old Jun 9, 2009 | 07:23 PM
wonderboy563's Avatar
scince you are replacing the bearing what i do on cars is to use a cut off wheel to cut about half way threw the race that is stuck then take a chisel and give it a good wack in the groove that you cut. it should crack then you can slide it rite off. make sure to wear saftey glasses they like to chip.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
ScopeZ_
Jul 28, 2015 01:44 AM
