250x cracked casing
Old Feb 17, 2001 | 12:41 PM
BayouEXrider's Avatar
I just bought a 92 250x in emmaculate shape for a pretty cheap price. The only thing is that the guy I bought it from failed to tell me that the casing was crack(a hairline crack)on the left side. The chain apparently came off and cracked it. I was wondering is there anything I can do to patch this up rather than buying a new casing cover?
Old Feb 17, 2001 | 12:58 PM
Tim1's Avatar
Silicone it,I had a 750 Yamaha Seca motorcycle and it had a button size hole in the side of the crank case and I put silcone over the hole and could not believe it held up under all the heat.I was going to fix it but I just told the guy who bought it to just keep a eye on it.
Old Feb 17, 2001 | 01:37 PM
RichardB's Avatar
You can remove the casing cover and have it welded back. While the silicon may work for a while, it will not prevent the crack from probagating under all the vibration these machines are exposed to. If you decide not to have it welded, you may want to drill a small hole at each end of the crack to help prevent further crack probagation prior to using a patching material. Also, instead of silicon, there are a number of patching materials available at most auto parts stores especially made for repairing metal.
Old Feb 17, 2001 | 01:45 PM
94DGblaster's Avatar
take the case off and coat each side with a liberal amount of JB weld.
It should hold it.
Old Feb 17, 2001 | 07:26 PM
Mike300ex's Avatar
Personally i'd just take it out and have a welder weld it back together. Either that, or keep an eye out on ebay i've seen a few people selling them over the last few months.
mike
Old Feb 18, 2001 | 01:33 AM
juggalo's Avatar
theres no need to get it welded. my counterbalncer broke off and put a hole in my case. my dad and i fixed it with a peice of metal and some JB weld. for just a little crack you could put JB weld on it and it will be fine.
Old Feb 18, 2001 | 08:23 PM
Thanks all but I decided to use JB Weld and it did it. Sealed up the crack without any leaks. Again thanks!!!
Old Feb 18, 2001 | 09:03 PM
MX265X's Avatar
keep your eye open for those sidecases youll prolly whack it again i have like 15 junk ones lying around i snag up everyone i can find i JB weld them till theres nothing left to them but thats only a temporary fix if you ride hard youll hit them. right now im making a case saver that should save it for a while if your running stock gearing i suggest you get one!
Old Feb 18, 2001 | 09:07 PM
thanks MX265X I think I am going to check that out for both my 250x and 300ex. Better to be safe than sorry!
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
WilliamBos
Sep 22, 2015 04:07 PM
